Stuck at octopi login and password. Default "pi" and "rasberry" not working.
Booting pi and remotely controlling with VNC worked. When I added octopi to boot disc with etcher, will not go past octopi login password. Can't login remotely to change with ssh because I can't see network now.
yes, no
Complete Logs
OctoPrint.org - Download & Setup OctoPrint
OctoPi 0.17.0, OctoPi version, printer, firmware, browser, Linux, ... as much data as possible
