I'm getting thermal runaway error
fans working . just started happening
no
no
OctoPrint version 1.5.3 rasberrypi 4 8 gig setup with wifi to windows 10
here are my logs
Recv: echo: cold extrusion prevented
Recv: ok
Send: N128513 G0 F9000 X186.899 Y102.077*127
Recv: ok
Send: N128514 G1 F1500 X180.065 Y101.958 E3512.97012*13
Recv: ok
Send: N128515 G0 F9000 X180.067 Y101.558*125
Recv: ok
Send: N128516 G1 F1500 X186.903 Y101.677 E3513.19752*6
Recv: ok
Send: N128517 G0 F9000 X186.906 Y101.277*125
Recv: ok
Send: N128518 G1 F1500 X180.07 Y101.158 E3513.42492*56
Recv: ok
Send: N128519 G0 F9000 X180.074 Y100.758*112
Recv: ok
Send: N128520 G1 F1500 X186.909 Y100.877 E3513.65229*4
Recv: ok
Send: N128521 G0 F9000 X186.913 Y100.477*123
Recv: ok
Send: N128522 G1 F1500 X180.077 Y100.358 E3513.87969*5
Recv: ok
Send: N128523 G0 F9000 X180.08 Y99.958*125
Recv: T:158.81 /200.00 B:59.99 /60.00 @:127 B@:127
Recv: ok
Send: N128524 G1 F1500 X186.916 Y100.077 E3514.10709*4
Recv: ok
Send: N128525 G0 F9000 X186.919 Y99.677*70
Recv: ok
Send: N128526 G1 F1500 X180.084 Y99.558 E3514.33446*50
Recv: ok
Send: N128527 G0 F9000 X180.087 Y99.158*70
Recv: ok
Send: N128528 G1 F1500 X186.923 Y99.277 E3514.56186*62
Recv: ok
Send: N128529 G0 F9000 X186.926 Y98.877*73
Recv: ok
Send: N128530 G1 F1500 X180.09 Y98.758 E3514.78926*7
Recv: ok
Send: N128531 G0 F9000 X180.094 Y98.358*64
Recv: ok
Send: N128532 G1 F1500 X186.93 Y98.477 E3515.01666*10
Recv: ok
Send: N128533 G0 F9000 X186.933 Y98.077*78
Recv: ok
Send: N128534 G1 F1500 X180.097 Y97.958 E3515.24406*50
Recv: ok
Send: N128535 G0 F9000 X180.101 Y97.558*64
Recv: T:157.80 /200.00 B:60.30 /60.00 @:127 B@:127
Recv: ok
Send: N128536 G1 F1500 X186.936 Y97.677 E3515.47143*55
Recv: ok
Send: N128537 G0 F9000 X186.94 Y97.277*115
Recv: ok
Send: N128538 G1 F1500 X180.104 Y97.158 E3515.69883*53
Recv: ok
Send: N128539 G0 F9000 X180.107 Y96.758*73
Recv: ok
Send: N128540 G1 F1500 X186.943 Y96.877 E3515.92623*50
Recv: ok
Send: N128541 G0 F9000 X186.946 Y96.477*67
Recv: ok
Send: N128542 G1 F1500 X180.111 Y96.358 E3516.1536*1
Recv: ok
Send: N128543 G0 F9000 X180.114 Y95.958*75
Recv: ok
Send: N128544 G1 F1500 X186.95 Y96.077 E3516.381*9
Recv: ok
Send: N128545 G0 F9000 X186.953 Y95.677*66
Recv: ok
Send: N128546 G1 F1500 X180.117 Y95.558 E3516.6084*13
Recv: ok
Send: N128547 G0 F9000 X180.121 Y95.158*65
Recv: T:156.82 /200.00 B:60.37 /60.00 @:127 B@:0
Recv: ok
Send: N128548 G1 F1500 X186.956 Y95.277 E3516.83577*54
Recv: ok
Send: N128549 G0 F9000 X186.96 Y94.877*113
Recv: ok
Send: N128550 G1 F1500 X180.124 Y94.758 E3517.06317*49
Recv: ok
Send: N128551 G0 F9000 X180.127 Y94.358*67
Recv: ok
Send: N128552 G1 F1500 X186.963 Y94.477 E3517.29057*58
Recv: ok
Send: N128553 G0 F9000 X186.966 Y94.077*68
Recv: ok
Send: N128554 G1 F1500 X180.131 Y93.958 E3517.51794*53
Recv: ok
Send: N128555 G0 F9000 X180.134 Y93.558*68
Recv: ok
Send: N128556 G1 F1500 X186.97 Y93.677 E3517.74534*1
Recv: ok
Send: N128557 G0 F9000 X186.973 Y93.277*65
Recv: ok
Send: N128558 G1 F1500 X180.137 Y93.158 E3517.97274*54
Recv: ok
Send: N128559 G0 F9000 X180.141 Y92.758*73
Recv: T:155.86 /200.00 B:60.37 /60.00 @:127 B@:0
Recv: ok
Send: N128560 G1 F1500 X186.976 Y92.877 E3518.20011*49
Recv: ok
Send: N128561 G0 F9000 X186.98 Y92.477*127
Recv: ok
Send: N128562 G1 F1500 X180.144 Y92.358 E3518.42751*61
Recv: ok
Send: N128563 G0 F9000 X180.147 Y91.958*75
Recv: ok
Send: N128564 G1 F1500 X186.983 Y92.077 E3518.65491*58
Recv: ok
Send: N128565 G0 F9000 X186.986 Y91.677*76
Recv: ok
Send: N128566 G1 F1500 X180.151 Y91.558 E3518.88227*58
Recv: ok
Send: N128567 G0 F9000 X180.154 Y91.158*69
Recv: ok
Send: N128568 G1 F1500 X186.99 Y91.277 E3519.10967*2
Recv: ok
Send: N128569 G0 F9000 X186.993 Y90.877*75
Recv: ok
Send: N128570 G1 F1500 X180.157 Y90.758 E3519.33708*49
Recv: ok
Send: N128571 G0 F9000 X180.161 Y90.358*71
Recv: T:154.78 /200.00 B:60.36 /60.00 @:127 B@:0
Recv: ok
Send: N128572 G1 F1500 X186.996 Y90.477 E3519.56444*54
Recv: ok
Send: N128573 G0 F9000 X187 Y90.077*84
Recv: ok
Send: N128574 G1 F1500 X180.164 Y89.958 E3519.79184*63
Recv: ok
Send: N128575 G0 F9000 X180.167 Y89.557*68
Recv: ok
Send: N128576 G1 F1500 X187.003 Y89.677 E3520.01924*63
Recv: ok
Send: N128577 G0 F9000 X187.006 Y89.277*66
Recv: ok
Send: N128578 G1 F1500 X180.171 Y89.158 E3520.24661*49
Recv: ok
Send: N128579 G0 F9000 X180.174 Y88.757*73
Recv: ok
Send: N128580 G1 F1500 X187.01 Y88.877 E3520.47401*3
Recv: ok
Send: N128581 G0 F9000 X187.013 Y88.477*72
Recv: ok
Send: N128582 G1 F1500 X180.177 Y88.357 E3520.70142*57
Recv: ok
Send: N128583 G0 F9000 X180.181 Y87.957*71
Recv: T:153.97 /200.00 B:60.23 /60.00 @:127 B@:0
Recv: ok
Send: N128584 G1 F1500 X187.016 Y88.077 E3520.92878*51
Recv: Error:Thermal Runaway, system stopped! Heater_ID: 0
Recv: Error:Printer halted. kill() called!
Changing monitoring state from "Printing" to "Error: Thermal Runaway, system stopped! Heater_ID: 0 - Printer halted. kill() called!"
Send: M112
Send: N128585 M112*18
Send: N128586 M104 T0 S0*17
Send: N128587 M140 S0*84
Changing monitoring state from "Error: Thermal Runaway, system stopped! Heater_ID: 0 - Printer halted. kill() called!" to "Offline (Error: Thermal Runaway, system stopped! Heater_ID: 0 - Printer halted. kill() called!)"
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x7f3bd9e6d8, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: start
Recv: echo: External Reset
Recv: Marlin 1.1.6.2
Recv:
Recv: echo: Last Updated: 2019-07-26 | Author: Ender-3 Pro
Recv: echo:Compiled: Aug 4 2019
Recv: echo: Free Memory: 10078 PlannerBufferBytes: 1232
Recv: echo:TF init fail
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 Pro EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: ok
Send: M155 S2
Recv: ok
