New to me Prusa with Octoprint, I set it up a few days ago and can't figure out how to connect to printer. I can see my cam using my browser working but when I try to connect it times out after 5 tries. Please help, I have never used Octoprint so this is all new to me, I followed directions of about 3 youtube vides and looked all over this forum and most of which is going over my head.
Yes
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyACM0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xa9fe6fe8, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: start
Send: N0 M110 N0125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
