Trying to use a Pi with Falsh Forge Creator Pro 2. Got the FlashForge Plugin (0.2.6) installed and permissions fixed, had to disable the GPX plugin to do it. If I re-enable the GPX plugin I get an error.
Disabled GPX
No, disabling GPX allows me to connect.
Complete Logs
Terminal Screen:
Changing monitoring state from "Offline" to "Opening serial connection"
Changing monitoring state from "Opening serial connection" to "Error: Connection error, see Terminal tab"
Changing monitoring state from "Error: Connection error, see Terminal tab" to "Offline (Error: Connection error, see Terminal tab)"
Unexpected error while connecting to serial port FlashForge Creator Pro 2 3D Printer, port:1:3, baudrate 115200 from hook GPX: FileNotFoundError: '[Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'' @ comm.py:_open_serial:3670
Octoprint Log:
2021-03-05 00:55:34,969 - octoprint.startup - INFO - ******************************************************************************
2021-03-05 00:55:34,970 - octoprint.startup - INFO - Starting OctoPrint 1.5.3
2021-03-05 00:55:34,970 - octoprint.startup - INFO - ******************************************************************************
2021-03-05 00:55:41,305 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
2021-03-05 00:55:41,305 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is not working
2021-03-05 00:55:41,306 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2021-03-05 00:55:41,313 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2021-03-05 00:55:41,404 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-03-05 00:55:42,590 - octoprint.plugins.flashforge - INFO - libusb1: 1.9.2
2021-03-05 00:55:42,630 - octoprint.startup - INFO - Added settings overlay from plugin firmware_check
2021-03-05 00:55:42,634 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 56 hook handlers
2021-03-05 00:55:42,759 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-03-05 00:55:42,777 - octoprint.server - INFO - Intermediary server started
2021-03-05 00:55:42,794 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-03-05 00:55:42,995 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-03-05 00:55:42,998 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2021-03-05 00:55:42,998 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2021-03-05 00:55:42,998 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2021-03-05 00:55:42,999 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2021-03-05 00:55:42,999 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_manage'), Need(method='role', value='plugin_announcements_read')")
2021-03-05 00:55:42,999 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2021-03-05 00:55:43,000 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2021-03-05 00:55:43,000 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2021-03-05 00:55:43,000 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2021-03-05 00:55:43,000 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2021-03-05 00:55:43,001 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2021-03-05 00:55:43,001 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
2021-03-05 00:55:43,001 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2021-03-05 00:55:43,001 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2021-03-05 00:55:43,002 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2021-03-05 00:55:43,654 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-05 00:55:44,169 - octoprint.util.pip - INFO - Version of pip is 20.3.3
2021-03-05 00:55:44,171 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-05 00:55:44,171 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-05 00:55:44,282 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-03-05 00:55:44,386 - octoprint.plugins.excluderegion - INFO - Logging mode set to 'octoprint'
2021-03-05 00:55:44,387 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=True, mayShrinkRegionsWhilePrinting=True, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding", "type": "ExcludedGcode"}, 'M117': {"gcode": "M117", "mode": "last", "description": "Suppress display messages while excluding and output the last message encountered when exiting the excluded area", "type": "ExcludedGcode"}, 'M204': {"gcode": "M204", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area", "type": "ExcludedGcode"}, 'M205': {"gcode": "M205", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area", "type": "ExcludedGcode"}, 'M73': {"gcode": "M73", "mode": "merge", "description": "Suppress progress updates while excluding and output the most recent progress values encountered when exiting the excluded area", "type": "ExcludedGcode"}}, atCommandActions={'ExcludeRegion': [{"command": "ExcludeRegion", "parameterPattern": "^\\s*(enable|on)(\\s|$)", "action": "enable_exclusion", "description": "Default action to enable exclusion", "type": "AtCommandAction"}, {"command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|$)", "action": "disable_exclusion", "description": "Default action to disable exclusion", "type": "AtCommandAction"}]}
2021-03-05 00:55:44,391 - octoprint.plugin.core - INFO - Initialized 26 plugin implementation(s)
2021-03-05 00:55:44,405 - octoprint.plugin.core - INFO - 26 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Autoscroll (0.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_autoscroll
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| BetterHeaterTimeout (1.3.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_BetterHeaterTimeout
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Exclude Region (0.3.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_excluderegion
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2021.2.4) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| FlashForge Plugin (0.2.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_flashforge
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| GcodeEditor (0.2.12) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_GcodeEditor
| GPX (2.6.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_GPX
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_navbartemp
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Themeify (1.2.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_themeify
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
| WebcamTab (0.2.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_webcamtab
2021-03-05 00:55:44,429 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 3959984128
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2021-03-05 00:55:44,439 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-03-05 00:55:44,455 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-03-05 00:55:45,009 - octoprint.server - INFO - Shutting down intermediary server...
2021-03-05 00:55:45,288 - octoprint.server - INFO - Intermediary server shut down
2021-03-05 00:55:45,290 - octoprint.events - INFO - Processing startup event, this is our first event
2021-03-05 00:55:45,290 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2021-03-05 00:55:45,294 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-03-05 00:55:45,294 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-03-05 00:55:45,325 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-03-05 00:55:45,343 - octoprint.plugins.flashforge - INFO - Found a FlashForge FlashForge Creator Pro 2 3D Printer, port:1:3
2021-03-05 00:55:45,346 - octoprint.server - INFO - Trying to connect to configured serial port FlashForge Creator Pro 2 3D Printer, port:1:3
2021-03-05 00:55:45,372 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2021-03-05 00:55:45,375 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-03-05 00:55:45,378 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-03-05 00:55:45,386 - octoprint.plugins.GPX - INFO - [a]
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - [b]
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - [left]
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - [machine]
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - [printer]
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - build_progress=1
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - ditto_printing=0
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - gcode_flavor=reprap
2021-03-05 00:55:45,387 - octoprint.plugins.GPX - INFO - machine_type=r2
2021-03-05 00:55:45,388 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2021-03-05 00:55:45,388 - octoprint.plugins.GPX - INFO - [right]
2021-03-05 00:55:45,388 - octoprint.plugins.GPX - INFO - [x]
2021-03-05 00:55:45,388 - octoprint.plugins.GPX - INFO - [y]
2021-03-05 00:55:45,388 - octoprint.plugins.GPX - INFO - [z]
2021-03-05 00:55:45,390 - octoprint.plugins.GPX - INFO - {'None': {}, 'a': {}, 'b': {}, 'left': {}, 'machine': {}, 'printer': {'build_progress': '1', 'ditto_printing': '0', 'gcode_flavor': 'reprap', 'machine_type': 'r2', 'recalculate_5d': '0'}, 'right': {}, 'x': {}, 'y': {}, 'z': {}}
2021-03-05 00:55:45,391 - octoprint.plugins.GPX - INFO - Connecting through x3g.
2021-03-05 00:55:45,393 - octoprint.plugins.GPX - INFO - GPXPrinter created, port: FlashForge Creator Pro 2 3D Printer, port:1:3, baudrate: 115200
2021-03-05 00:55:45,395 - octoprint.plugins.GPX - INFO - gpx.connect raised exception = [Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'
2021-03-05 00:55:45,396 - octoprint.plugins.GPX - INFO - Failed to connect to x3g e = [Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'.
2021-03-05 00:55:45,412 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Error: Connection error, see Terminal tab"
2021-03-05 00:55:45,413 - octoprint.util.comm - INFO - Changing monitoring state from "Error: Connection error, see Terminal tab" to "Offline (Error: Connection error, see Terminal tab)"
2021-03-05 00:55:45,414 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port FlashForge Creator Pro 2 3D Printer, port:1:3, baudrate 115200 from hook GPX: FileNotFoundError: '[Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'' @ comm.py:_open_serial:3670
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 3670, in _open_serial
settings().getFloat(["serial", "timeout", "connection"]),
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1890, in wrapper
return f(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_GPX/__init__.py", line 130, in serial_factory
self.printer = GpxPrinter(self, port, baudrate, timeout)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_GPX/gpxprinter.py", line 46, in __init__
self._settings.get_boolean(["verbose"])))
FileNotFoundError: [Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'
2021-03-05 00:55:45,416 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error
2021-03-05 00:55:45,419 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-05 00:55:46,189 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creator Pro 2"._http._tcp.local.' for _http._tcp.local.
2021-03-05 00:55:47,003 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creator Pro 2"._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-03-05 00:55:47,046 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-03-05 00:55:47,117 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-05 00:55:47,710 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-05 00:55:47,716 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-05 00:55:47,716 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-05 00:55:47,783 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 110.4GB. That is considered sufficient for updating.
2021-03-05 00:55:47,783 - octoprint.plugins.softwareupdate - INFO - Not fetching check overlays, we are offline
2021-03-05 00:55:48,075 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-05 00:55:51,398 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-03-05 00:55:51,401 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-05 00:55:51,401 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-05 00:55:51,463 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-03-05 00:55:51,472 - octoprint.plugins.themeify - INFO - Themeify initialized.
2021-03-05 00:55:51,608 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://10.0.1.89/', 'path': '/', 'query_string': 'l10n=en'}
2021-03-05 00:55:56,436 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.0.1.118
2021-03-05 00:55:56,517 - octoprint.server.util.flask - INFO - Passively logging in user MarkLeeber from ::ffff:10.0.1.118
2021-03-05 00:55:56,517 - octoprint.access.users - INFO - Logged in user: MarkLeeber
2021-03-05 00:55:56,801 - octoprint.plugins.flashforge - INFO - Found a FlashForge FlashForge Creator Pro 2 3D Printer, port:1:3
2021-03-05 00:55:56,991 - octoprint.plugins.flashforge - INFO - Found a FlashForge FlashForge Creator Pro 2 3D Printer, port:1:3
2021-03-05 00:55:57,601 - octoprint.plugins.flashforge - INFO - Found a FlashForge FlashForge Creator Pro 2 3D Printer, port:1:3
2021-03-05 00:55:57,928 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2021-03-05 00:55:57,972 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-05 00:55:59,231 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-03-05 00:55:59,415 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-05 00:55:59,658 - octoprint.server.util.sockjs - INFO - User MarkLeeber logged in on the socket from client ::ffff:10.0.1.118
2021-03-05 00:55:59,947 - octoprint.server.preemptive_cache - INFO - ... done in 8.34s
2021-03-05 00:55:59,948 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://octopi.local/', 'path': '/', 'query_string': 'l10n=en'}
2021-03-05 00:56:00,180 - octoprint.server.preemptive_cache - INFO - ... done in 0.23s
2021-03-05 00:57:39,355 - octoprint.plugins.GPX - INFO - [a]
2021-03-05 00:57:39,355 - octoprint.plugins.GPX - INFO - [b]
2021-03-05 00:57:39,355 - octoprint.plugins.GPX - INFO - [left]
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - [machine]
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - [printer]
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - build_progress=1
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - ditto_printing=0
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - gcode_flavor=reprap
2021-03-05 00:57:39,356 - octoprint.plugins.GPX - INFO - machine_type=r2
2021-03-05 00:57:39,357 - octoprint.plugins.GPX - INFO - recalculate_5d=0
2021-03-05 00:57:39,357 - octoprint.plugins.GPX - INFO - [right]
2021-03-05 00:57:39,357 - octoprint.plugins.GPX - INFO - [x]
2021-03-05 00:57:39,357 - octoprint.plugins.GPX - INFO - [y]
2021-03-05 00:57:39,357 - octoprint.plugins.GPX - INFO - [z]
2021-03-05 00:57:39,362 - octoprint.plugins.GPX - INFO - {'None': {}, 'a': {}, 'b': {}, 'left': {}, 'machine': {}, 'printer': {'build_progress': '1', 'ditto_printing': '0', 'gcode_flavor': 'reprap', 'machine_type': 'r2', 'recalculate_5d': '0'}, 'right': {}, 'x': {}, 'y': {}, 'z': {}}
Serial log:
2021-03-05 00:55:45,370 - Changing monitoring state from "Offline" to "Opening serial connection"
2021-03-05 00:55:45,411 - Changing monitoring state from "Opening serial connection" to "Error: Connection error, see Terminal tab"
2021-03-05 00:55:45,412 - Changing monitoring state from "Error: Connection error, see Terminal tab" to "Offline (Error: Connection error, see Terminal tab)"
2021-03-05 00:55:45,414 - Unexpected error while connecting to serial port FlashForge Creator Pro 2 3D Printer, port:1:3, baudrate 115200 from hook GPX: FileNotFoundError: '[Errno 2] No such file or directory: 'FlashForge Creator Pro 2 3D Printer, port:1:3'' @ comm.py:_open_serial:3670
Plugin_GPX log:
Opening port: FlashForge Creator Pro 2 3D Printer, port:1:3.
Octoprint Version 1.5.3
GPX (2.6.8)
