For a while now being able to control and print to my Flashforge Creator Pro from Octopi has been very random. One time when I power the printer and connect I can instantly jog the print head and everything works flawlessly, the next time there is no movement. If it was working and I send the M18 power down steppers I can power them up again but cannot control them again that session. The terminal shows an ok returned though for all movement commands.
Today I went to the octopi page (it is always running) and powered up the printer but no control, tried re-powering the printer, restarting octopi with printer on and off, rebooting octopi, all with no change.
If I try to print when I cannot jog first the head slams into the front left side of the printer, the opposite corner to the home switches. If it is at the home position it will try to home the Z axis at about 1mm per minute until it times out and will print in fresh air. Then it crashes the table down into the floor.
Gcode comes from Simplify3D and there is no issue if printing from SD card.
Of course, the second I finish typing I reset the connection to get clean startup text and it works.
Top text probably non working Bottom is the latest working extract
Changing monitoring state from "Offline" to "Error: Connection error, see Terminal tab"
Unexpected error while connecting to serial port: AUTO IOError: 'GPX plugin not able to discover AUTO port and/or baudrate. Please choose specific values for them.' @ comm.py:_openSerial:2478 (hook GPX)
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6b9cb558>, starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Recv: start
Recv: Sailfish v7.8
Recv: echo: gcode to x3g translation by GPX
Send: N0 M110 N0*125
Recv: SD card ok
Recv: T:22 /0 B:12 /0 T0:22 /0 T1:22 /0 @:0 B@:0
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Sailfish FIRMWARE_VERSION:7.8 FIRMWARE_URL:http://www.sailfishfirmware.com MACHINE_TYPE:r1d EXTRUDER_COUNT:2
Send: M20
Recv: ok
Recv: Begin file list
Recv: DCIM
Recv: skyfan_front.x3g
Recv: dashcam mount.x3g
Recv: oculus sensor R.x3g
Send: <p>M72 P1<br>M70 P15 (Octoprint in control)</p>
Recv: nolan_test3.x3g
Recv: ok
Recv: // echo: (line 2) Syntax error: unrecognised gcode '<p>M72 P1<br>M70 P15 (Octoprint in control)</p>'
Recv: Rock_Lrg_04.x3g
Recv: desk hole.x3g
Recv: cam_mount3.x3g
Recv: desk hole covers.x3g
Recv: belt tops.x3g
Recv: flamingoKH.x3g
Recv: ocu_box_bottom.x3g
Recv: mth800-stand2.x3g
Recv: telematics cover2.x3g
Recv: blower holder.x3g
Recv: blower holder2.x3g
Recv: fibre pen.x3g
Recv: End file list
Send: M105
Recv: ok T:22 /0 B:13 /0 T0:22 /0 T1:22 /0 @:0 B@:0
Send: M105
Recv: ok T:23 /0 B:11 /0 T0:23 /0 T1:22 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 X-10 F2500
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F2500
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:22 /0 B:12 /0 T0:22 /0 T1:23 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 X-10 F2500
Changing monitoring state from "Operational" to "Offline"
Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6b9c5ad0>, starting monitor
Recv: start
Recv: Sailfish v7.8
Recv: SD card ok
Recv: T:23 /0 B:14 /0 T0:23 /0 T1:23 /0 @:0 B@:0
Recv: ok
Recv: ok
Send: N1 M115*39
Send: M20
Recv: ok
Recv: DCIM
Recv: ok
Recv: desk hole.x3g
Recv: belt tops.x3g
Recv: fibre pen.x3g
Recv: End file list
Send: M105
Recv: ok T:23 /0 B:13 /0 T0:23 /0 T1:23 /0 @:0 B@:0
Send: M105
Recv: ok T:23 /0 B:14 /0 T0:23 /0 T1:23 /0 @:0 B@:0
