Flashforge dreamer works perfectly with Octoprint ver 1.7.3. After successfully upgrading to 1.8.0 it wont connect anymore.
I reinstalled ver 1.73 and it works, but then tried 1.80 again and it wont connect
YES
NO
Performing autodetection with 7 port/baudrate candidates: FlashForge Dreamer 3D Printer, port:1:8@115200, FlashForge Dreamer 3D Printer, port:1:8@250000, FlashForge Dreamer 3D Printer, port:1:8@230400, FlashForge Dreamer 3D Printer, port:1:8@57600, FlashForge Dreamer 3D Printer, port:1:8@38400, FlashForge Dreamer 3D Printer, port:1:8@19200, FlashForge Dreamer 3D Printer, port:1:8@9600
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: <octoprint_flashforge.flashforge.FlashForge object at 0x6d67e0f0>, starting monitor
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 250000
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 230400
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 57600
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 38400
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 19200
Trying port FlashForge Dreamer 3D Printer, port:1:8, baudrate 9600
Changing monitoring state from "Detecting serial connection" to "Error"
Using an approved power supply for the raspberry Pi
Also removed 5V pin in the USB cable
octoprint-systeminfo-20220912142510.zip (106.2 KB)
