I have a question about flow rate in octoprint. I know that it cannot be reported back when you change it in the interface but that leaves me confused as to how it handles subsequent changes. If I make a change to flow rate and then make another change to it is it changing the absolute flow rate modification or is it adding those flow rates together. For instance if I were to change the flow rate to 50% and then change it to 75% is the final flow rate 75% or 75% of 50%?
Also does that flow rate change persist for another print. I'm not asking if I turn it off and turn it back on I'm asking if I start another print leaving octoprint up and running will it keep that modified flow rate for the next print?
I looked in the documentation and found nothing addressing these two questions. I think they're pretty important does it really will alter how I handle adjusting flow rate. I know that the best thing to do is adjust flow rate in the slicer but I like to adjust flow rate on the fly while I'm doing tuning and sometimes I need to do fine adjusting to account for different colors / diameter differences in filament.
Thanks!
