In Settings>Folders every Folder is not writable.
I checked that the rights are set for pi
2020-01-24 12:06:38,916 - octoprint.server.api - ERROR - Error while testing if /home/pi/.octoprint/timelapse is really writable
File "/home/pi/OctoPrint/venv/lib/python3.7/site-packages/octoprint/server/api/__init__.py", line 383, in _test_path
f.write("Test")
TypeError: a bytes-like object is required, not 'str'
OctoPrint 1.4.0rc3 with Python3 on Rasbian
Screenshot:
Settings > Folders
