I want to run different start scripts depending on which printer profile is being used but I cant work out how to reference the profile name. I think the script syntax is OK, it doesn't create any errors. It should be something like:-
{% if printer_profile.name == "profile name" %}
GCODE to be actioned if the current profile has that name
{% else %}
GCODE to be actioned if not that profile name
{% endif %}
but that doesn't work. The syntax works fine but I cant get a true result for the profile name no matter what I try.
Looking though the forum there are a couple of entries saying its possible but none detail the correct syntax and another that explains the printer_profile attributes have not been documented, it links to code but I just dont understand enough about the code to get the information I need.
Link to comment here.
Not relevant
Not applicable
Complete Logs
Logs show nothing.
Octoprint Version 1.5.2
Octopi Version 0.17.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Hi @Ewald_Ikemann I have a Pi for every printer but this one is a Snapmaker 3in1 that does CNC and laser as well as print. I was wanting to use OctoPrint to at least monitor stuff or possibly run some non print work. The 3D printing is also "managed" in some strange ways. I have an OctoPrint script that actually does bed leveling and uses the probe to bed distance to set the head height - which it the standard processes don't do. When I saw you could use If statements in the GCODE scrips I thought that should be easy then I spent ages searching for the format or an example and then trying every combination I could think off. If it's not a runner I will just have to put the code into cura profiles.
@Charlie_powell, great idea.
M117 {{ printer_profile.name }} returned the correct profile name Snap3DPrintLevel
Now what am I doing wrong with the if statement:
{% if printer_profile.name == "snap3Dprintlevel" %}
which always returns false.
Having got this to work for the single profile it would be great if I could get it to do something else if the profile being used is not the one in the "if" statement using say "else", "elseif" or two separate "if" statements.
Can this be done? I have tried a number of options but unless the profile is the one specified in the first "if" statement everything is ignored.
Here are two of the options I have tried, I have also tried
;bed level and Z offsite profile v1
{% if printer_profile.name == "Snap3DPrintLevel" %}
G21 ;set units to millimetre
M140 S65 ; set bed temp for bed level
G90 ;set absolute positioning
G28 ;home need as printer sometimes "lost"
M190 S65 ; wait for bed temp
;Auto Level
G1029 A ;start levelling
G91; relative positioning for Z offset move
G0 Z-3.8; Device specific Z offset, reduce to bring print closer to the bed (bigger minus number). (equivalent to M851)
G1029 S ;save data
G1029 D0 ;end levelling
G0 Z10; move up 10mm
G90; restore absolute positioning
{% endif %}
{% if printer_profile.name == "Snap3DPrintNoLevel" %}
G90 ;absolute positioning
M140 S65 ; start bed heat to save time
G28 ;home to match levelling script and to avoid some bed crash scenarios
{% endif %}
;bed level and Z offsite profile v2
;Auto Level
G1029 S ;save data
{% else %}
