I decided to flash octoprint on a new, faster SD card. The old card was very cheap and possibly degrading, plus it was running the Python 2 version of Octoprint so I figured this was a good way to start fresh. After installing Octoprint through the image recommended image burner (which I have used before), Octoprint will not connect over the web interface. I get a IP refused to connect. The router assigned the same IP and device name after the reinstall. I am able to SSH into the Pi.
I assigned a different IP address and changed the device name on the router. Based on this post, I tried installing Samba on the PI, updating the Windows host file,
I'm using a Google Home mesh network. The Pi is successfully connecting to the home network at 2.4GHz, same as before the new SD card.
