has anyone seen a Raspberry Pi HAT (similar to this one https://blog.protoneer.co.nz/raspberry-pi-cnc-board-hat/) that is supported by Octoprint?
That would be neat for newly built DIY printers, for existing printers w/ a broken motor controller board or for printers where a smoothieboard plus a raspberry pi board are too large in space.
So that specific Pi Hat looks like an arduino nano (or similar) and 3 stepper drivers. I haven't personally seen anything like that, but in theory you could flash marlin on the arduino side (if it fits) and be able to control 3 axes. Unfortunately, you need at least 4 for a printer and enstops/thermistorsm etc. Neat idea though for a compact integrated solution. I did find this project...
https://easyeda.com/jamaalwillis1/Raspberry-Pi-Delta-Hat
This is interesting, but the question is why do it, or what advantage would this have at all over current method, and if the effort worth it. I can't think of any advantage that a hat (connecting via GPIO) would have vs. connecting via serial/USB-to-serial.
...other than losing the serial cable and a source of induced noise in the communication line.
meh... nothing that good quality cables can't solve
is the best solution when you want to use klipper an octoprint.
