What changes need to be made in the g-code generated in Lightburn to run the task.
Gcode Processing Failed - 1 of 2
No Definite Position
Unable to find a definite position
.lb_kolo.gcode (2.3 KB)
I'm afraid you are in the wrong subforum.
Assuming this is not a Guide and you need help you just should choose Get Help.
'Gcode Processing Failed' is not a message that OctoPrint generates. It's from one of your plugins - I second the point that a 'Get Help' topic rather than a guide would be better here.
'Gcode Processing Failed' is not a message that OctoPrint generates. It's from one of your plugins - I second the point that a 'Get Help' topic rather than a guide would be better here.lb_kolo.gcode (2.4 KB)
What's so special about posting a problem to 'Get Help'?
Easy, It offers the template which structures the initial post and which infos are needed.
Filling this out properly makes it WAY more likely to get help quickly
You've just pasted a message that I wrote in response to your question in the previous thread, that doesn't really work
Set minimum move speed in lightburn.
You error is G0X14 Y0 F0 <--- change that f0 to f1500 and it works. (make sure its the only F0 for speed)
