I've been having issues with Temp sensors on my Ender 3. Can't seem to figure out why my nozzle temp is stuck at 229 degrees Celsius and bed temp is stuck at 191.
I've replaced Thermistor, Heating Element, and checked for poorly soldered pins/bad connections.
Serial port list: []
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Serial port list: [u'COM3']
Connecting to: COM3
Connected to: Serial<id=---, open=True>(port='COM3', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Recv: start
Send: N0 M110 N0*125
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: echo: External Reset
Recv: Marlin 1.1.6.2
Recv:
Recv: echo: Last Updated: 2018-11-28 | Author: (Ender-3)
Recv: echo:Compiled: May 24 2019
Recv: echo: Free Memory: 10078 PlannerBufferBytes: 1232
Recv: echo:TF init fail
Recv: ok
Send: N1 M115*39
Recv: ok
Send: N2 M21*18
Recv: Error:Line Number is not Last Line Number+1, Last Line: 0
Recv: Resend: 1
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: N2 M21*18
Recv: Cap:EEPROM:1
Recv: Cap:Z_PROBE:0
Recv: ok
Send: M105
Recv: ok
Send: M155 S2
Recv: ok T:231.00 /0.00 B:190.45 /0.00 @:0 B@:0
Send: M155 S2
Recv: ok
Send: M105
Recv: ok
Fresh install of OctoPrint on Windows 10, Ender 3X, Brand new Heating Element and Thermistor.
This is the Error I get when I try to preheat
Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: MAXTEMP triggered, system stopped! Heater_ID: bed - Printer halted. kill() called!
