From about 2 weeks ago octoprint behaves strange while mixing up gcode start code scripts and object gcode script from Slicer. Temp is raised earlier as coded in startscript - fan ain´t powerd up as coded in object gcode.
I´m slicing with ideamaker. There are no start end end scripts for the job defined cause I`ve all the start end endcode in octoprint gcode scripts.
The octoprint startscript
- powers off all motors and fans
- initializes any marlin setting that has not to be hard coded in firmware like PID / TMC Current / Speed / Jerk / Acceleration etc.
- prepowers nozzle to 150 and bed to 70 degree with no wait
- powers up object fan to 100%
- homes and Z-levels axis, does an UBL scan of the bed
- powers down object fan, goes to X0,Y0,Z4 and powers nozzle to 220 degree and bed to 70 with wait commands
- does intro line
8 starts gcode print job
Since two weeks this standard routine used for a long time is mixed up in two ways.
even before step 5 (see above) is started nozzle temp is set to nozzle temp from gcode print job file and. This temp can´t be changed - how many 150 degree commands I place in the gcode startcode on whatever position.
the fan is not powered on - even if in sliced gcode there is a layer 2 = 50% and layer 3 = 75% fan power code. This can´t be fixed with fan slider on octoprint control-panel. Only fan settings on LCD display will allow to set the fan power the right way.
If i just copy the gcode startcode in terminal window it runs fine and any command works as intended.
Only if I start a real print job this gcode mixup happens.
Disabled preheat plugin and removed it completely - problem stays the same.
This problem only occurs on my multi color head (1 nozzle and 3 extruders). The printer has an easy to change platform with different single color / single nozzle extruder buildup. For this I do have a different installation of octoprint that´s swapped along with the extruder. On this single plattform the code mixup doesn´t take place.
Sliced a version of the stl file in the multi color setup, only using 1 color and removed any tool switching T0 / T1 command from the gcode header as well as any T0 /T1 temp lines from the gcode. gcode mixup still keeps on going...
Complete Logs
Octoprint Version 1.4.2
raspi 3+
