when you ftp gcode into the upload folder it does an analysis of each file. However it seems to completely re-scan them again after every restart. This is causing restarts to take a significant time and causing laggy responses when first access the web ui after a restart
I've looked through the logs and identified it is rescanning the files after each restart. I've looked through the config for a setting to stop this but can't find one
Yes thats what i thought so i deleted tbe meta data file let it rescan ovet night tnen rebooted and it starts the scan again.
The reason ive ftp'd a loaf of files is i had to reinstall octoprobt as it kept dailing to update from 1.6 due to me still having py2. Went for fresh intstall and just copied tje gcode files back over
The watched directory has been there for a while. It's specifically for uploading outside of OctoPrint/OctoPrint API. Once a file is placed there OctoPrint will detect, analyze, and move to uploads.
Yes i've just read that in the doc link you sent me. Thank you. I'm going to delete all my uploads and then re-ftp into the watched folder and let it scan and move over. It's been a while since i manually transferred anything over as i normally upload directly via cura.
Thank you for your help - I'll mark as solved if this fixes it
