GCODE Scripts - trying to send a long line to printer causes a checksum error.
I split my call to assign a macro M812 into two and it worked as the lines did not wrap within the little window it gives you.
I doubt highly it affects this behaivour. octoprint-systeminfo-20211108010126.zip (214.9 KB)
1.7.2, no idea, ender 3 pro with E3 SKR board, marlin 2.0.9, chrome, win10, pc.
Here are the functions I am trying to assign to gcode macros. Such macros have one glaring omission -- that is, they can be written, executed, but NOT read. So to counter that I had to load them in anew from a easily visible area, such as gc scripts.
The first two, M810, M811 went in fine. M812 and M815 had "no checksum" errors, there were *nn numbers shown being sent at each line terminal. I don't know if there is a arbitrary limit to how long lines sent can be, or some odd character is screwing up the parity check. I copied them to a notepad and widened it, it stayed on one line.
M810 M300 S2000 P3
M811 M300 P10 S2200 | M300 P8 S2750 | M300 P4 S3250
M812 M300 S3800 P4000 | M300 S3200 P2000 | M300 S2800 P6000 | M117 Load Next... | M220 S11
M813 M300 P10 S1800
;Peek Routine
M815 M300 P80 | G91 | G1 E-6 | G0 Z+1 | G90 | G0 Y200 | G0 ;X225 | M117 Waiting 20S for inspection | G4 S20 | M300 P500 ;| M117 Going Back... | G4 S3 | G91 | G0 Z-1 | G90 | M117 Resumed. | M300 P100
I'm trying to streamline things a bit without redundant bits of gcode here and there, especially not from Cura's tiny-ass post-process interface that shows like 18 characters. I'd gladly include a log of it, but serial log deletes itself every time it resets -- nice feature for debugging when it crashes.
