Gcode Scrips are not being executed with current configuration.
Searched Forum for Problem and could not find recent event for this problem.
SSH'd into PI to check that scripts were present. Yes they are. Edited and re-saved and current scripts do show up as updated.
Ran in Safe Mode and Scripts are now working correctly.
Have not tried to disable individual PlugsIns yet until I posted here to see if review of system information dialog could isolate which plugin to test.
Yes
Yes. Running In Safe Mode corrected problem and Scripts run correctly and show up in the Terminal Screen Tab. Cannot determine Which Plugin is causing issue.
2021-11-15 17:59:44,738 - octoprint.util.comm - ERROR - Error while processing hook dashboard for phase sending and command G1 Y0.40 E9.0 F1000.0:
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 4611, in _process_command_phase
tags=tags,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1737, in wrapper
return f(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_dashboard/__init__.py", line 801, in process_gcode
current_layer_progress = int((self.layer_moves / self.layer_move_array[self.current_layer]) * 100)
ZeroDivisionError: division by zero
2021-11-15 17:59:44,787 - octoprint.util.comm - ERROR - Error while processing hook dashboard for phase sending and command G1 X5.0 E20.0 F1000.0:
tags=tags,
It is the dashboard plugin. This bug was fixed by the author, and updating to 1.19.5 (the latest version as I write this) should fix the issue. There's similar exceptions in the log for the whole beforePrintStarted script, line by line.
EDIT: Double checked, seems you are on the latest version already?
OK Dashboard is causing the problem. I have posted report on GitHub to see what's up.
I have current version 1.19.5 and it only happening on Start of Print (Might also be end of Print but have not tested that one yet).
I disabled Dashboard and it started to work again.
