Slicer (name, version, operating system)
Cura 4.4.1, windows 10
I usually export my designs directly from Fusion 360 to cura, slice and save the gcode in OctoPrint. I have changed several parameters, but with this design in particular and with 0.06 layer height, OctoPrint GCODE viewer shows an empty layer at z=0.028 (layer n°4, not a multiple of 0.06), and upon checking the .gcode file, aside from some initial routines I can't find any Z axis related command that puts the bed at a height of 0.28. As far as I understand, the viewer is only that, a viewer, and doesn't modify de file or has any impact on the print, but the print fails exactly at that height, and all the filament forms a blob around the extruder.
Change bunch of parameters in cura, the only one affecting the issue is the layer height (and I really need to print with that layer height).
Logs
octoprint.log (33.5 KB)
Example GCODE file
CE5_d4fbe08e-89cb-4476-84ab-84e355034b37.gcode (3.9 MB)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware...)
OctoPrint 1.3.12, , Creality ender 5 with board 1.1.5 and marlin 2.0.1
