It seems there is no posibillity to save the setting for GcodeViewer.
Iwould like to have prevered setting without changing every time.
So I like to have
zoomed on Model
not to show movings an retracts
also show previous layer
Each time when I start the function old setting is active..
I use version 1.3.10 with a wanhao duplicator i3.
Is there a ini-file to save settings or can I make it?
I would like to join this request. Just having learned that chosen options aren't yet stored in an *.ini (resp. *.yaml-) file (see here) I suggest to change this behaviour. It would be great storing the chosen options in config.yaml in a future release.
I decided to continue this old conversation because typing the headline for an intended new conversations leads me to this place.
Thanks for reading and perhaps further improving this great software.
I believe the Gcode Viewer IS preserving the chosen options. Please open a new Get Help topic and fill in the template because if it isn't working for you, it will require more details for us to figure out how to help.
