Connected to a GEEETECH i3 Pro C via OctoPrint using a RASPI PI 1 through ethernet.
i can set preheat temps which change on the screen but the printer does not heat. Also manual control does not seem to work either but i have definitely have a connection to the printer
yes i did try turn it off and on again
multiple reboots and fireware checks
disconnecting and reconnecting printer
Logs (octoprint.log, serial.log or output on terminal tab, ...)
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0xb2e486b0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0*125
Baudrate test retry #1
Baudrate test retry #2
Baudrate test retry #3
Recv: �Np|xF�6~i *6�If�BpON&�HOY�-�J=\x1aG"pYt\x17Oa8�U.6f�HGI�-p|HF\x03�~�Y\x08\x086�M�'��-Q�\x17\x12F�\x1b>\x17jW&��\x17\x12\x03aH>�\x07
Baudrate test retry #4
Trying baudrate: 250000
Recv: }M�6\x1b�8�echo:Unknown command: "\x18"
Recv: ok
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: ok
Send: N2 M21*18
Recv: FIRMWARE_NAME:V1.0.04 Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/Ultimaker/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:I3proC EXTRUDER_COUNT:2 UUID:00000000-0000-0000-0000-000000000000
Recv: 0123456789abcdef
Recv: hardware:v1.05
Recv: ok
Recv: echo:SD init fail
Recv: ok
Send: M140 S60.0
Recv: ok
Send: M104 T0 S210.0
Recv: ok
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
octoprint version: 1.3.11
OctoPi version 0.16.0
