Generation of Octoprint plugin skeleton fails when using the "octoprint dev plugin:new" or " cookiecutter gh:OctoPrint/cookiecutter-octoprint-plugin" command with the following trace:
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Scripts\octoprint.exe\__main__.py", line 7, in <module>
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\__init__.py", line 1008, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1078, in main
rv = self.invoke(ctx)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1688, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\cli\common.py", line 37, in invoke
return self._impl.invoke(ctx)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1682, in invoke
cmd_name, cmd, args = self.resolve_command(ctx, args)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\click\core.py", line 1729, in resolve_command
cmd = self.get_command(ctx, cmd_name)
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\cli\dev.py", line 65, in get_command
commands = self._get_commands()
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\cli\dev.py", line 55, in _get_commands
for command in self._get_commands_from_prefix_methods(f"{group}_"):
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\cli\dev.py", line 48, in _get_commands_from_prefix_methods
result = method()
File "C:\Users\Till\PycharmProjects\2FAPluginOctoprint\OctoPrint\src\octoprint\cli\dev.py", line 70, in plugin_new
import cookiecutter.main
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\cookiecutter\main.py", line 22, in <module>
from .repository import determine_repo_dir
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\site-packages\cookiecutter\repository.py", line 11, in <module>
REPO_REGEX = re.compile(r"""
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\__init__.py", line 227, in compile
return _compile(pattern, flags)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\__init__.py", line 294, in _compile
p = _compiler.compile(pattern, flags)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\_compiler.py", line 743, in compile
p = _parser.parse(p, flags)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\_parser.py", line 980, in parse
p = _parse_sub(source, state, flags & SRE_FLAG_VERBOSE, 0)
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\_parser.py", line 455, in _parse_sub
itemsappend(_parse(source, state, verbose, nested + 1,
File "C:\Users\Till\AppData\Local\Programs\Python\Python311\Lib\re\_parser.py", line 841, in _parse
raise source.error('global flags not at the start '
re.error: global flags not at the start of the expression at position 1 (line 2, column 1)
Google the problem, tried to install different cookiecutter versions
reinstalling the environment and the plugin an development dependencies
Octoprint not running
Windows
New Octoprint installation
virtualenv used
