The camera fails to initialize. I have to unplug/replug every time the pi restarts.
I've tried switching ports. I tested it on my pc and it works fine.
[ 85.151120] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[ 85.281918] usb 1-1.4: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInte rval 32, changing to 9
[ 85.282393] usb 1-1.4: New USB device found, idVendor=1c3f, idProduct=2002, bcdDevice= 1.00
[ 85.282411] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 85.282426] usb 1-1.4: Product: WEB CAM
[ 85.282441] usb 1-1.4: Manufacturer: WCM_USB
[ 85.284344] uvcvideo: Found UVC 1.00 device WEB CAM (1c3f:2002)
[ 85.284564] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
[ 85.286988] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaroun d.
[ 85.287698] uvcvideo 1-1.4:1.0: Entity type for entity Extension 4 was not initialized!
[ 85.287718] uvcvideo 1-1.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 85.287735] uvcvideo 1-1.4:1.0: Entity type for entity Processing 5 was not initialized!
[ 85.287753] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 85.288170] input: WEB CAM: WEB CAM as /devices/platform/scb/fd500000.pcie/pci0000:00/0000: 00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input1
[ 85.295659] usb 1-1.4: Warning! Unlikely big volume range (=5120), cval->res is probably wr ong.
[ 85.295679] usb 1-1.4: [5] FU [Mic Capture Volume] ch = 1, val = 7680/12800/1
Octoprint Version 1.4.2 Octopi Version 0.17.0, running on Raspberry Pi 4 Model B Rev 1.1
