Get Raspberry Pi Hardware INFO
I would like to know the type of RaspBerry Pi OCTOprint is running on. i.e: PI 1,2,3,4 or Model A,B,C or Ram 1Gb,2Gb,4Gb,8Gb.
I cannot physically access the Pi's Logic/Circuit board to see that.
Looked for a Plug-In :slight_smile:
Resource Monitor and Dashboard do not seem to provide all that information.
N/A
N/A
Complete Logs
N/A
N/A
Apologise, partly silly Me :frowning:
[screenshot]https://www.dropbox.com/s/flrstdx7lktdbqo/Screenshot%202021-03-19%20at%2010.04.21.png?dl=0
This does show 'some' info such as:
env.plugins.pi_support.model : Raspberry Pi Model B Rev 2
It would be nice if this could be expanded to include memory amount.
RAM or SD Card?
Raspberry Pi Ram
Cheers,
James.
Should be in the info list:
env.hardware.ram:
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:86.0) Gecko/20100101 Firefox/86.0
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 916783104
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 20.2.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
Thank you Ewald,
I wish this is in MB and GB
I do hope my lack of vision helps others who follow :slight_smile:
Could anyone give me a hand and help me how to calculate/convert the env.hardware.ram value into GB or MB?
mine is 3970777088
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:144.0) Gecko/20100101 Firefox/144.0
connectivity.connection_check: 192.168.?.?:53
connectivity.enabled: True
connectivity.online: True
env.hardware.freq: 1800.0
env.hardware.ram: 3970777088
env.os.bits: 32
env.os.id: linux
env.os.platform: Linux-6.1.21-v7l+-armv7l-with-glibc2.31
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.10.2-20240618085851
env.plugins.pi_support.octopiuptodate_build_short: 2024.06.18.085851
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2025-02-10T21:21:02Z
octoprint.last_safe_mode.reason: incomplete_startup
octoprint.safe_mode: False
octoprint.version: 1.11.3
printer.firmware: Marlin 2.1.1 (May 20 2023 00:19:16)
systeminfo.generated: 2025-10-25T10:20:22Z
systeminfo.generator: zipapi
Kind regards.
