When I connect to octoprint I can get in once, then malwarebytes browser guide (I'm not sure where it even came from) comes up with a security error attempt at redirect and I get http://octoprint :5000/login/?redirect=%2F%3F&permissions=STATUS,SETTINGS_READ
I am running ubuntu server and have octoprint installed to it with the usb web camera working. The host name is octoprint. I am accessing it via Edge on Windows 11.
If I clean everything octoprint from the Edge history I can get to it again one time. If I change to the ip address rather than the host name it doesn't seem to make any difference. If I don't log out of octoprint sometimes it connects back, other times I get this same message. I'm sure this is not a problem with Octoprint but didn't know where else to turn for help.
