Raspberry Pi Cam Module v2 (imx219, 3280x2464 max. resolution)
I am using the telegram notifications plugin to get updates via telegram. But the pictures are not oriented the same way as in the webinterface.
In the control tab all is displayed/oriented like I configured it (horizontally and vertically flipped). But when I get a telegram notification with a picture none of those configurations are applied and it is rotated 180° clockwise. I checked the webcam page and found out that when I click "test stream url" the same happens... The picture in the result frame is also not oriented as configured (rotate 180°) and therefore standing on its head. Same applies to snapshot test...
Noticed this behavior since the switch to OctoPrint 1.4.1.
disabling/re-enabling webcam, different flip configurations, tinkered with octopi.txt settings for raspi camera (resolution), also tried this fix from the telegram notification plugin with no success
dmesg.log (20.3 KB) syslog.log (659.5 KB) webcamd.log (980.8 KB)
OctoPrint Version 1.4.2
OctoPi Version 0.15.1, running on Raspberry Pi 3 Model B Rev 1.2
