GPIO10 already used | run octoprint as root? & how?
The SPI GPIO-Pin "10" is already in use (Touchscreen)
In order to use the "RGB Status" plugin, i would need to connect the data pin to GPIO10, or run octoprint as root (to use another GPIO Pin)
Tried to add the "pi" user to "gpio"-Group -> already is.
I tried to run octoprint as root, but I am not really sure how to do so.
Hello @Hasinator!
SPI is a bus system (https://en.wikipedia.org/wiki/Serial_Peripheral_Interface). You should be able to connect both to pin 10.
Thank you for your quick response
I tried connecting both to pin 10 -> didn't work
Tried another RaspberryPi with no touchscreen driver installed -> works
conclusion: connecting both to pin 10 doesn't work
According to the Wiki I linked, you may put the links in serial.
1st
RaspiMosi -> TouchscreenMosi | TouchscreenMiso -> LED-DataIn | LED-DataOut -> RaspiMiso
= doesn't work (LED & Touchscreen)
2nd
RaspiMosi -> TouchscreenMosi & LED-DataIn | TouchscreenMiso & LED-DataOut -> RaspiMiso
= doesn't work (LED & Touchsceen)
3rd
RaspiMosi -> TouchscreenMosi & LED-DataIn | TouchscreenMiso -> RaspiMiso
= doesn't work (LED) -> Touchscreen works
Update:
I didn't get the Neopixels working in series with the touchscreen.
I did get octoprint running as root though:
  • mounted the octopi sd card (on another pi or any linux machine)
  • edited the /etc/sudoers file (passwordless sudo)
    pi ALL=(ALL:ALL) NOPASSWD:ALL
  • edited the /etc/default/octoprint file:
    OCTOPRINT_USER=root
    DAEMON_ARGS=--iknowwhatimdoing
Maybe someone can use these instructions.
Please note that this might be a security issue!
additional info:
  • connected LED-DataIn to Pin 21 (BCM)
  • i am using a level shifter (3,3V to 5V)
