Is there an option i have overseen that let me see the needed filament weight on the particular print?
At the moment it shows the needed lenght and volume:
Well, i hoped the is a parameter provided by the slicer to tell octoprint the value.
Where did the length and cm³ come from?
The only thing which seems relevant to me inside the gcode is this:
filament_density = 1.27
That implies that you provide the values to the slicer.
But every slicer puts this value into the gcode file in a different way.
But I'm sure, this could be done with a plugin.
That is calculated from the amount of the filament that is used.
This should be relatively simple to estimate from the length of filament used. A 1 Kg spool of 1.75 mm filament is approximately 335 M length, so a quick estimate is very close to 3 gm / meter length.
