My gui is not loading properly and everything is a jumbled mess. The elements are there, but they don't seem to be mapped out properly. I got it to work for a print yesterday by clearing browser cache, but this time that is not working. I am using chrome on linux most of the time. The issue is the same of firefox on the same machine.
I tried the suggestions found here but it does not seem to work. I do have an error in the chrome console for glyphicon-halflings.png failed.
Rebooting in safe mode did not work. I tried to remove the easy-install.pth, but it said it could not find it.
The pi is throttled, but I knew about that since I have an LED on one of the USB ports. It's been like that for some time now. I have removed it since the issue came up. No change.
OCTOPRINT LOG:
2020-04-19 13:36:26,826 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-19 13:36:26,852 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-04-19 13:36:26,853 - octoprint.server - INFO - OctoPrint 1.4.0
2020-04-19 13:36:26,860 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/errortracking
| Filament Manager (0.5.3) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_filamentmanager
| Logging (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging
| Login UI (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/loginui
| Pi Support Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| PSU Control (0.1.9) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_psucontrol
| Software Update (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2020-04-19 13:36:26,893 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 900.0
| ram: 917020672
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 2 Model B Rev 1.1
| python:
| pip: 19.1.1
| version: 2.7.13
| virtualenv: /home/pi/OctoPrint/venv
2020-04-19 13:36:26,894 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-04-20 09:21:27,163 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 09:22:02,623 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 243930}
2020-04-20 09:26:01,725 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:26:31,829 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:31:31,895 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:32:31,972 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:36:27,166 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 09:37:02,633 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 244830}
2020-04-20 09:37:32,088 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:41:32,539 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:46:32,607 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:47:32,727 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:51:27,170 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 09:52:02,636 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 245730}
2020-04-20 09:52:32,775 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 09:56:03,196 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:01:03,257 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:03:33,636 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:06:27,174 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 10:07:02,699 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 246630}
2020-04-20 10:08:33,652 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:11:03,988 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:21:04,120 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:21:27,177 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 10:22:02,720 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 247530}
2020-04-20 10:27:04,805 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:32:04,853 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:33:35,057 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:36:27,181 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 10:37:02,716 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 248430}
2020-04-20 10:38:35,123 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:41:05,488 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:46:05,527 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:46:35,550 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:51:27,183 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 10:51:35,673 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:52:02,682 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 249330}
2020-04-20 10:54:05,977 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 10:59:06,065 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:06:06,864 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:06:27,187 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 11:07:02,729 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 250230}
2020-04-20 11:11:06,991 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:13:07,251 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:18:07,349 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:21:27,192 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 11:22:02,745 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 251130}
2020-04-20 11:22:37,860 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:27:37,894 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:28:38,093 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:33:38,071 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:36:27,194 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 11:36:38,461 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:37:02,717 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 252030}
2020-04-20 11:41:38,534 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:42:38,702 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:47:38,820 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:48:38,915 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:51:27,198 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 11:52:02,715 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 252930}
2020-04-20 11:53:39,026 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:54:39,108 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 11:59:39,173 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:02:39,552 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:06:27,202 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 12:07:02,760 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 253830}
2020-04-20 12:07:39,576 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:11:10,036 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:16:10,103 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:17:10,173 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:21:27,206 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 12:22:02,930 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 254730}
2020-04-20 12:22:10,313 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:25:40,732 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:35:40,828 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:36:10,886 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:36:27,211 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 12:37:02,747 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 255630}
2020-04-20 12:41:11,022 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:41:41,099 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:51:27,214 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 12:51:41,169 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:52:02,774 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 256530}
2020-04-20 12:52:11,280 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 12:57:11,337 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:04:12,131 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:06:27,218 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 13:07:02,819 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 257431}
2020-04-20 13:09:12,189 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:10:12,336 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:15:12,392 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:21:27,221 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-04-20 13:22:02,802 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 258331}
2020-04-20 13:23:43,437 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:28:43,549 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:30:43,799 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-04-20 13:35:43,863 - octoprint.plugins.tracking - INFO - Sent tracking event system_throttled, payload: {'throttled_mask': 327685, 'throttled_voltage_now': True, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': True, 'throttled_past': True, 'throttled_overheat_past': False}
BROSWER LOG:
Failed to load resource: net::ERR_CONNECTION_RESET
less.min.js:13 Less has finished and no sheets were loaded.
packed_core.js?3514a079:16964 Starting dependency resolution...
packed_core.js?3514a079:17074 ... dependency resolution done
packed_core.js?3514a079:17384 Initial application setup done, connecting to server...
packed_core.js?3514a079:15010 Connected to the server
packed_core.js?3514a079:17349 Finalizing application startup
packed_core.js?3514a079:17224 Going to bind 36 view models...
packed_core.js?3514a079:17277 Did not bind view model UsageViewModel to target #wizard_plugin_tracking since it does not exist
packed_core.js?3514a079:17277 Did not bind view model SoftwareUpdateViewModel to target #softwareupdate_confirmation_dialog since it does not exist
packed_core.js?3514a079:17277 Did not bind view model SoftwareUpdateViewModel to target #wizard_plugin_softwareupdate since it does not exist
packed_core.js?3514a079:3334 User girard logged in
packed_core.js?3514a079:17316 ... binding done
packed_core.js?3514a079:17328 Application startup complete
DevTools failed to load SourceMap: Could not load content for chrome-extension://ekhagklcjbdpajgpjgmbionohlpdbjgc/browser-polyfill.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
DevTools failed to load SourceMap: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/include.preload.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
DevTools failed to load SourceMap: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/include.postload.js.map: HTTP error: status code 404, net::ERR_UNKNOWN_URL_SCHEME
This is running on:
processor : 0
model name : ARMv7 Processor rev 5 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 5
It does have a number of services running on it. Pihole and a
wordpress server.
Here's a screenshot of it:
Thanks!
