What is the easiest way to get a Graphic User Interface on the OctoPi (Rasberry Pi 3B) ?
I would like to be able to connect keyboard, mouse and screen to my OctoPi, so I can control the printer using that instead of the printers UI.
I do plan to use wifi as everybody else when I'm in my office.
As I understand it, OctoPi does not come with a GUI installed by default, so what is the easiest way to get that installed.
P.s. I have not yet installed the OctoPi, I'm doing some research and planning so I hopefully get it right the first time.
So far thats correct, when you ssh into your OctoPi you get following "hint":
This image comes without a desktop environment installed because it's not
required for running OctoPrint. If you want a desktop environment you can
install it via
sudo /home/pi/scripts/install-desktop
