GUI unreachable after uploading a file
Every time I do upload a gcode, I lose the Wifi connection to Octoprint for approx. two minutes.
Everything is working fine: I can operate the printer via the interface, heat up/cool down, I can see the camera picture, move the head/bed,…
Until I send a gcode file to the printer: Then I can’t reach the interface anymore for approx. 2-3 minutes.
It doesn’t matter if I send it to “local” or to the printer’s SD card. Also sending the data directly from Prusaslicer via API shows the same effect: As soon as the upload starts, the connection to Octoprint gets lost and the gui is unreachable for a while. The behavior is even the same when the printer is not connected!
Nothing has changed on the configuration of the RPi or the network lately.
  • I changed the power supply
  • I changed the sd card in my Raspberry
  • I made a complete fresh installation with RPi imager without(!) even restoring the backup
n/a
octoprint-systeminfo-20260207113859.zip (45.6 KB)
Build 2026.01.27.133909 with "webcamd", based on OctoPi 1.1.0, running on Raspberry Pi 4 Model B Rev 1.4
