I had octopi running fine and then I couldn't connect. Then reformatted sd card using sd card formatter amd flashed the octopi image. Used same config changes as before but now am not able to see it connected to network and get a timeout error when connecting to the IP Address I had before. It usually used the same ip address even when setting it up multiple times in the past.
Log into your router. It probably assigned a different IP when the DHCP lease expired
NOW SOLVED - There was an issue with the bigger SD Card. Using an 8GB one now and all flashed and found properly! Thanks for your help
This was also the case! Thanks
It was primarily the SD card being funny though. Which is odd because it was a San disk but was 64gb
