HAPROXY not working properly?
haproxy is not redirecting traffic to port 80
compare configs with my other octoprint server
I have a new Octoprint server which I've built following the official directions for a linux build. I'm using dietpi on a nanopc-t4. I have done this build countless times without issue. however, this time I cannot get haproxy working properly.
I have generated a new SSL cert for 443 access. here is my haproxy config:
global
maxconn 4096
user haproxy
group haproxy
daemon
log 127.0.0.1 local0 debug
defaults
log global
mode http
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind :::80 v4v6
bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
default_backend octoprint
backend octoprint
reqrep ^([^\ :])\ /(.) \1\ /\2
option forwardfor
backend webcam
reqrep ^([^\ :])\ /webcam/(.) \1\ /\2
server webcam1 127.0.0.1:8080
Everything looks correct to me....Any help would be appreciated.
it turned out to be a cert issue. I regenerated the cert and it started working.
