I'm setting up Octoprint on a Pi4 with Bullseye installed. OP setup went just fine and it works well. I cannot get Haproxy to run properly. I can do the basic install, and it runs, but does not give me the proper results (that is, access to OP via only the IP address without the ":5000." As soon as I update the .cfg file, I get an error when starting Haproxy. I tried the things suggested in the Reverse Proxy thread to no avail. Anyone run into this before?
