After updating from 1.5.mumble to 1.5.3, attempts to view a print in the GCode Viewer tab never show, and trying to print causes the printer to throw an error and disconnect. When I looked in octoprint.log I see lines like:
2021-01-25 21:23:58,255 - tornado.application - ERROR - Uncaught exception GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21)
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/web.py", line 1592, in _execute
result = yield result
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/gen.py", line 1133, in run
value = future.result()
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/concurrent.py", line 261, in result
raise_exc_info(self._exc_info)
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/gen.py", line 326, in wrapper
yielded = next(result)
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/web.py", line 2525, in get
for chunk in content:
File "/home/octoprint/OctoPrint/local/lib/python2.7/site-packages/tornado/web.py", line 2689, in get_content
chunk = file.read(chunk_size)
IOError: [Errno 5] Input/output error
2021-01-25 21:23:58,303 - tornado.access - ERROR - 500 GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21) 517.85ms
However, relative to my .octoprint directory, that file is located at uploads/test_prints/OUT_CE3_tempTower_220_250.gcode
Everything was working prior to the 1.5.3 upgrade.
I tried making a symbolic link downloads -> uploads but that didn't help.
Complete Logs
2021-01-25 21:21:45,486 - octoprint.startup - INFO - ******************************************************************************
2021-01-25 21:21:45,490 - octoprint.startup - INFO - Starting OctoPrint 1.5.3
2021-01-25 21:21:45,501 - octoprint.startup - INFO - ******************************************************************************
2021-01-25 21:21:47,984 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2021-01-25 21:21:47,992 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2021-01-25 21:21:47,995 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2021-01-25 21:21:48,842 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2021-01-25 21:21:49,152 - octoprint.plugin.core - INFO - Loading plugins from /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins, /home/octoprint/.octoprint/plugins and installed plugin packages...
2021-01-25 21:21:50,629 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin did not pass check, not loading.
2021-01-25 21:21:53,469 - octoprint.plugin.core - WARNING - Plugin Marlin GCode Documentation (0.9.0) is not compatible to Python 2.7.13 (compatibility string: >=3,<4).
2021-01-25 21:21:54,483 - octoprint.plugin.core - INFO - Found 21 plugin(s) providing 20 mixin implementations, 44 hook handlers
2021-01-25 21:21:54,898 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-01-25 21:21:54,977 - octoprint.server - INFO - Intermediary server started
2021-01-25 21:21:55,083 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/octoprint/.octoprint/uploads...
2021-01-25 21:21:57,468 - octoprint.filemanager.storage - INFO - ... file metadata for /home/octoprint/.octoprint/uploads initialized successfully.
2021-01-25 21:21:57,487 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2021-01-25 21:21:57,496 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2021-01-25 21:21:57,507 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2021-01-25 21:21:57,517 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2021-01-25 21:21:57,527 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2021-01-25 21:21:57,537 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2021-01-25 21:21:57,543 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2021-01-25 21:21:57,556 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2021-01-25 21:21:57,566 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2021-01-25 21:21:57,577 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-01-25 21:21:57,586 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-01-25 21:21:57,597 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2021-01-25 21:21:57,606 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2021-01-25 21:21:57,614 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2021-01-25 21:21:57,687 - octoprint.printer.standard - INFO - Using print time estimator provided by PrintTimeGenius
2021-01-25 21:21:58,573 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-01-25 21:22:01,375 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/bin/python2 -m pip" as command to invoke pip
2021-01-25 21:22:03,833 - octoprint.util.pip - INFO - Version of pip is 20.0.2
2021-01-25 21:22:03,843 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-25 21:22:03,849 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-25 21:22:03,917 - octoprint.plugin.core - INFO - Initialized 20 plugin implementation(s)
2021-01-25 21:22:04,000 - octoprint.plugin.core - INFO - 21 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Active Filters Extended (0.1.0) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_active_filters_extended
| Announcement Plugin (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/backup
| Bed Visualizer (1.0.0) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Core Wizard (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_firmware_check
| Firmware Updater (1.7.7) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| GCode Viewer (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/logging
| *Marlin GCode Documentation (0.9.0) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_marlingcodedocumentation
| Plugin Manager (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| PrintTimeGenius Plugin (2.2.7) = /home/octoprint/OctoPrint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Software Update (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/octoprint/OctoPrint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2021-01-25 21:22:04,084 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 1008.0
| ram: 514813952
| os:
| bits: 32
| platform: linux2
| python:
| pip: 20.0.2
| version: 2.7.13
| virtualenv: /home/octoprint/OctoPrint
2021-01-25 21:22:04,178 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/webassets...
2021-01-25 21:22:04,541 - octoprint.server - INFO - Reset webasset folder /home/octoprint/.octoprint/generated/.webassets-cache...
2021-01-25 21:22:08,057 - octoprint.server - INFO - Shutting down intermediary server...
2021-01-25 21:22:08,204 - octoprint.server - INFO - Intermediary server shut down
2021-01-25 21:22:08,217 - octoprint.events - INFO - Processing startup event, this is our first event
2021-01-25 21:22:08,227 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2021-01-25 21:22:08,237 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-01-25 21:22:08,257 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-01-25 21:22:08,458 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-01-25 21:22:08,651 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-01-25 21:22:08,854 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-01-25 21:22:08,861 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-01-25 21:22:08,872 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-01-25 21:22:09,048 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 5 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyS1@115200, /dev/ttyS0@115200, /dev/ttyS3@115200, /dev/ttyS2@115200
2021-01-25 21:22:09,054 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyACM0, baudrate 115200
2021-01-25 21:22:09,065 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2021-01-25 21:22:09,088 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-01-25 21:22:09,104 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-25 21:22:09,152 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-01-25 21:22:09,173 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-01-25 21:22:09,200 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2021-01-25 21:22:09,231 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2021-01-25 21:22:09,385 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin TH3D U2.R1.B3"
2021-01-25 21:22:09,452 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-01-25 21:22:09,566 - octoprint.util.comm - INFO - Firmware states that it supports sd status autoreporting
2021-01-25 21:22:09,786 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on chip._http._tcp.local.' for _http._tcp.local.
2021-01-25 21:22:10,158 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 115200, u'printer_port': None, u'firmware_name': u'Marlin TH3D U2.R1.B3'}
2021-01-25 21:22:10,647 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on chip._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-01-25 21:22:10,685 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on chip for SSDP
2021-01-25 21:22:10,851 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2021-01-25 21:22:11,091 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-01-25 21:22:12,139 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.21
2021-01-25 21:22:13,285 - octoprint.server.util.flask - INFO - Passively logging in user octodrew from 192.168.1.21
2021-01-25 21:22:13,304 - octoprint.access.users - INFO - Logged in user: octodrew
2021-01-25 21:22:13,551 - octoprint.server.util.sockjs - INFO - User octodrew logged in on the socket from client 192.168.1.21
2021-01-25 21:22:16,412 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-01-25 21:22:20,027 - octoprint.util.pip - INFO - Using "/home/octoprint/OctoPrint/bin/python2 -m pip" as command to invoke pip
2021-01-25 21:22:20,030 - octoprint.util.pip - INFO - pip installs to /home/octoprint/OctoPrint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-01-25 21:22:20,044 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-01-25 21:22:20,109 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 4.9GB. That is considered sufficient for updating.
2021-01-25 21:22:20,335 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2021-01-25 21:22:21,245 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 28}
2021-01-25 21:22:22,257 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.13', u'bits': 32, u'ram': 514813952, u'version': u'1.5.3', u'plugins': u'bedlevelvisualizer:1.0.0,firmwareupdater:1.7.7,active_filters_extended:0.1.0,printtimegenius:2.2.7', u'pip': '20.0.2', u'cores': 1, u'freq': 1008.0, u'os': u'linux'}
2021-01-25 21:22:22,617 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.90:5000/'}
2021-01-25 21:22:23,265 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.13', u'os': u'linux', u'ram': 514813952, u'version': u'1.5.3', u'pip': '20.0.2', u'cores': 1, u'freq': 1008.0, u'bits': 32}
2021-01-25 21:22:30,079 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-01-25 21:22:46,998 - octoprint.server.util.flask - INFO - Passively logging in user octodrew from 192.168.1.21
2021-01-25 21:22:47,005 - octoprint.access.users - INFO - Logged in user: octodrew
2021-01-25 21:23:37,794 - octoprint.server.preemptive_cache - INFO - ... done in 75.18s
2021-01-25 21:23:38,240 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.21
2021-01-25 21:23:40,958 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.21
2021-01-25 21:23:41,168 - octoprint.server.util.flask - INFO - Passively logging in user octodrew from 192.168.1.21
2021-01-25 21:23:41,175 - octoprint.access.users - INFO - Logged in user: octodrew
2021-01-25 21:23:48,468 - octoprint.server.util.sockjs - INFO - User octodrew logged in on the socket from client 192.168.1.21
2021-01-25 21:23:55,716 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: test_prints/OUT_CE3_tempTower_220_250.gcode, owner: octodrew, user: octodrew
2021-01-25 21:23:56,952 - tornado.application - ERROR - Uncaught exception GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21)
2021-01-25 21:23:56,997 - tornado.access - ERROR - 500 GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21) 644.76ms
2021-01-25 21:23:57,464 - tornado.application - ERROR - Uncaught exception GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21)
2021-01-25 21:23:57,489 - tornado.access - ERROR - 500 GET /downloads/files/local/test_prints/OUT_CE3_tempTower_220_250.gcode (192.168.1.21) 418.59ms
2021-01-25 21:36:54,916 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-01-25 21:37:21,072 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 928}
OctoPrint 1.5.3 on an NTC C.H.I.P. running Debian stretch. Single core ARM v7 Allwinner cpu (R-12 I think), 512MB ram, 8GB flash filesystem.
