I've been having issues getting Octoprint to configure camera settings at startup.
I set up a script per the following guide.
Works fine when I run the script manually but it doesn't appear that the script is loading at startup.
I've made sure that the script has the a and x attributes.
I noticed that octoprint keeps re-arranging the command line, placing it before the subscriptions field?
Any help would be much appreciated!
