Hello, So I've run into a dead end trying to communicate with my RPI 4 to give it some needed commands I believe by ssh. For the record, I've never gotten this to work and I was never able to get into the rasbian os or octopi, from the get go when I initially setup my RPI4. I just went straight to the octoprint wizard and got the rpi up and running and off to printing. The RPI is currently plugged into the printer and wirelessly connected to my home network. I can see the ip address on my router page and I use this ip address in my browser (on windows 10) to use octoprint. This has been working flawless for months. Now, I have some settings I would like to change (or add) for a webcam and cannot connect via ssh ing in command prompt. I believe not setting up my RPI from the get go, by changing it's default username and password is why I'm having troubles now, or I feel that was a needed step I skipped. In command prompt when I type in ssh pi@octopi.local I get "no such host is known". If I type ssh (ip address) of the rpi it asks for password. I don't know what password it could want. I've tried all of them, including "raspberry" permission denied. I'm NOT good at this lingo, so please be kind :).
I have reinstalled the octoprint instance numerous times and have never gotten it to ask me for the default "username and password" ever using Command prompt. I can see the RPI's ip address on my router and am able to log into octoprint via the ip address in my browser.
I do have Bonjour installed in my computer
I have not tried running it in safe mode. My computer? Or Octoprint? Not sure this applies to my issue?
Complete Logs
ssh: could not resolve hostname octopi.local: No such hose is known.
password: permission denied. please try again.
I have latest octoprint and octopi. Printers are Creality. Using Chrome on Windows 10
Have Putty installed and Bonjour networking
