I would like to use Device tab in the OrcaSlicer to run OctoPrint. Unfortunately it manages to load very rarely. Most often 9/10 cases in just says Socket connection failed. ...
Here is the message that appears in logs:
2024-01-20 22:22:03,037 - octoprint.server.util.flask - INFO - Passively logging in user xxx from 192.168.x.x
2024-01-20 22:22:03,038 - octoprint.access.users - INFO - Logged in user: xxx
2024-01-20 22:22:03,406 - octoprint.server.util.flask - INFO - Passively logging in user xxx from 192.168.x.x
2024-01-20 22:22:03,406 - octoprint.access.users - INFO - Logged in user: xxx
2024-01-20 22:22:04,263 - octoprint.server.util.flask - INFO - Passively logging in user xxx from 192.168.x.x
2024-01-20 22:22:04,263 - octoprint.access.users - INFO - Logged in user: xxx
I tried making another user for OrcaSlicer but I did not get opportunity to log in ever since. Always the same behavior. Is there any option to disable this passively logging in?
I can send printing jobs via OrcaSlicer to the printer without any problems.
I have tried in safe mode the same issue persists
