Raspberry Pi Camera Module 3
I am trying to set up my Module 3 camera and is not detecting the camera. I have verified that the connector is connected properly and in the right direction and not in the display connector.
I have configured octopi.txt to be "camera=raspi" and restarted octopi with no luck and don't know what else to do (see octopi.txt below).
### Windows users: To edit this file use Notepad++, VSCode, Atom or SublimeText.
### Do not use Notepad or WordPad.
### MacOSX users: If you use Textedit to edit this file make sure to use
### "plain text format" and "disable smart quotes" in "Textedit > Preferences"
### Configure which camera to use
# Available options are:
# - auto: tries first usb webcam, if that's not available tries raspi cam
# - usb: only tries usb webcam
# - raspi: only tries raspi cam
# Defaults to auto
camera="raspi"
### Additional options to supply to MJPG Streamer for the USB camera
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to a resolution of 640x480 px and a framerate of 10 fps
#camera_usb_options="-r 1440x1080 -f 30"
### Additional webcam devices known to cause problems with -f
# Apparently there a some devices out there that with the current
# mjpg_streamer release do not support the -f parameter (for specifying
# the capturing framerate) and will just refuse to output an image if it
# is supplied.
# The webcam daemon will detect those devices by their USB Vendor and Product
# ID and remove the -f parameter from the options provided to mjpg_streamer.
# By default, this is done for the following devices:
# Logitech C170 (046d:082b)
# GEMBIRD (1908:2310)
# Genius F100 (0458:708c)
# Cubeternet GL-UPC822 UVC WebCam (1e4e:0102)
# Using the following option it is possible to add additional devices. If
# your webcam happens to show above symptoms, try determining your cam's
# vendor and product id via lsusb, activating the line below by removing # and
# adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff"
# additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
# If this fixes your problem, please report it back so we can include the device
# out of the box: https://github.com/guysoft/OctoPi/issues
#additional_brokenfps_usb_devices=()
### Additional options to supply to MJPG Streamer for the RasPi Cam
# See https://faq.octoprint.org/mjpg-streamer-config for available options.
# NOTE: Newer raspi cam modules are reporting as usb devices causing these
# options to be ignored. Set `camera="raspi"` to avoid these issues.
# Defaults to 10fps
# camera_raspi_options="-x 1920 -y 1080 -fps 50"
### Configuration of camera HTTP output
# Usually you should NOT need to change this at all! Only touch if you
# know what you are doing and what the parameters mean.
# Below settings are used in the mjpg-streamer call like this:
# -o "output_http.so -w $camera_http_webroot $camera_http_options"
# Current working directory is the mjpg-streamer base directory.
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
### EXPERIMENTAL
# Support for different streamer types.
# Available options:
# mjpeg [default] - stable MJPG-streamer
# hls - experimental FFMPEG HLS streamer
#camera_streamer=mjpeg
octoprint-systeminfo-20230904100703.zip (378.4 KB)
Raspberry Pi 3B+, OctoPrint version: 1.9.2, OctoPi version: Build 2022.09.27.151125, based on OctoPi 0.18.0, Ender 3 Pro
If the best option would be just to reinstall OctoPi since I had it installed before the new camera backend, I can do that but would prefer to avoid that option.
Any help is appreciated!
Thank you.
