New Creality Ender 5 Plus fails with Heatbed Failed displayed on its LCD. Here's the catch. This only happens when sending a print via Octoprint. A gcode file loaded via SD card directly to the E5+ and the bed/hotend heated via the LCD works and prints normally.
Reset EEPROM, shutdown restarted PC, RPi, and E5+ numerous times.
Yes, no change.
No change.
Complete Logs
2021-03-21 01:11:03,533 - octoprint.startup - INFO - ******************************************************************************
2021-03-21 01:11:03,534 - octoprint.startup - INFO - Starting OctoPrint 1.5.3
2021-03-21 01:11:03,535 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2021-03-21 01:11:03,536 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2021-03-21 01:11:03,537 - octoprint.startup - INFO - ******************************************************************************
2021-03-21 01:11:03,906 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2021-03-21 01:11:03,966 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2021-03-21 01:11:03,967 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2021-03-21 01:11:03,967 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2021-03-21 01:11:04,620 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2021-03-21 01:11:04,642 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-03-21 01:11:05,409 - octoprint.plugin.core - INFO - Plugin Tasmota (0.8.13) is disabled.
2021-03-21 01:11:05,604 - octoprint.startup - INFO - Added settings overlay from plugin firmware_check
2021-03-21 01:11:05,605 - octoprint.plugin.core - INFO - Found 36 plugin(s) providing 17 mixin implementations, 34 hook handlers
2021-03-21 01:11:05,830 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-03-21 01:11:05,844 - octoprint.server - INFO - Intermediary server started
2021-03-21 01:11:05,863 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-03-21 01:11:06,092 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-03-21 01:11:06,095 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2021-03-21 01:11:06,096 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2021-03-21 01:11:06,097 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2021-03-21 01:11:06,098 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2021-03-21 01:11:06,098 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2021-03-21 01:11:06,099 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2021-03-21 01:11:06,100 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2021-03-21 01:11:06,101 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2021-03-21 01:11:06,102 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2021-03-21 01:11:06,103 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2021-03-21 01:11:06,104 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-03-21 01:11:06,105 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2021-03-21 01:11:06,107 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2021-03-21 01:11:06,107 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2021-03-21 01:11:06,108 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2021-03-21 01:11:06,340 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-03-21 01:11:06,879 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-03-21 01:11:07,392 - octoprint.util.pip - INFO - Version of pip is 20.1.1
2021-03-21 01:11:07,393 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-21 01:11:07,394 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-21 01:11:07,408 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2021-03-21 01:11:07,422 - octoprint.plugin.core - INFO - 36 plugin(s) registered with the system:
| !ABL Expert Plugin (0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ABL_Expert
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| !Autoselect Plugin (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_autoselect
| !Bed Visualizer (1.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| !BetterHeaterTimeout (1.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_BetterHeaterTimeout
| !DisplayZ (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_displayz
| !Extra Distance Buttons (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_extradistance
| !Fan Speed Control (0.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fanspeedslider
| File Check (2021.2.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2021.2.4) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| !Firmware Updater (1.10.9) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| !Fullscreen Plugin (0.0.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| !ipOnConnect (0.2.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ipOnConnect
| !M73 Progress Plugin (0.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_m73progress
| !Marlin EEPROM Editor (3.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin
| !Navbar Temperature Plugin (0.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_navbartemp
| !Preheat Button (0.7.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| !Simple Emergency Stop (1.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_simpleemergencystop
| !Tab Order (0.5.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_taborder
| !Tasmota (0.8.13) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_tasmota
| !Terminal Commands Extended (0.1.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_terminalcommandsextended
| !Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2021-03-21 01:11:07,451 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 3928305664
| os:
| bits: 64
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.1.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2021-03-21 01:11:07,468 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-03-21 01:11:07,495 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-03-21 01:11:08,027 - octoprint.server - INFO - Shutting down intermediary server...
2021-03-21 01:11:08,464 - octoprint.server - INFO - Intermediary server shut down
2021-03-21 01:11:08,465 - octoprint.events - INFO - Processing startup event, this is our first event
2021-03-21 01:11:08,466 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2021-03-21 01:11:08,473 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-03-21 01:11:08,474 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-03-21 01:11:08,475 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-03-21 01:11:08,479 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-03-21 01:11:08,526 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-21 01:11:09,652 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-21 01:11:09,669 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-03-21 01:11:09,702 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-21 01:11:09,707 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-03-21 01:11:09,710 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-03-21 01:11:09,721 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2021-03-21 01:11:09,727 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:11:09,729 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:11:09,746 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-03-21 01:11:09,749 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:11:09,948 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 3831, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 6455, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 596, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2021-03-21 01:11:09,973 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2021-03-21 01:11:09,975 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831)"
2021-03-21 01:11:09,978 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-21 01:11:10,529 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "EZPi Pro"._http._tcp.local.' for _http._tcp.local.
2021-03-21 01:11:11,338 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "EZPi Pro"._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-03-21 01:11:11,347 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "EZPi Pro" for SSDP
2021-03-21 01:11:11,361 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-03-21 01:11:11,364 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2021-03-21 01:11:11,686 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-03-21 01:11:12,355 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2021-03-21 01:11:12,443 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-03-21 01:11:12,505 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-03-21 01:11:12,591 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 24.0GB. That is considered sufficient for updating.
2021-03-21 01:11:12,641 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.23
2021-03-21 01:11:12,893 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2021-03-21 01:11:13,089 - octoprint.server.util.flask - INFO - Passively logging in user Greg from ::ffff:192.168.1.23
2021-03-21 01:11:13,100 - octoprint.access.users - INFO - Logged in user: Greg
2021-03-21 01:11:13,176 - octoprint.server.util.sockjs - INFO - User Greg logged in on the socket from client ::ffff:192.168.1.23
2021-03-21 01:11:13,223 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.15/'}
2021-03-21 01:11:19,421 - octoprint.server.preemptive_cache - INFO - ... done in 6.20s
2021-03-21 01:11:40,577 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.23
2021-03-21 01:11:40,841 - octoprint.server.util.flask - INFO - Passively logging in user Greg from ::ffff:192.168.1.23
2021-03-21 01:11:40,842 - octoprint.access.users - INFO - Logged in user: Greg
2021-03-21 01:11:41,063 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.23
2021-03-21 01:11:41,138 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.23
2021-03-21 01:11:41,794 - octoprint.server.util.flask - INFO - Passively logging in user Greg from ::ffff:192.168.1.23
2021-03-21 01:11:41,795 - octoprint.access.users - INFO - Logged in user: Greg
2021-03-21 01:11:42,473 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.23
2021-03-21 01:11:42,517 - octoprint.server.util.flask - INFO - Passively logging in user Greg from ::ffff:192.168.1.23
2021-03-21 01:11:42,518 - octoprint.access.users - INFO - Logged in user: Greg
2021-03-21 01:11:44,447 - octoprint.server.util.sockjs - INFO - User Greg logged in on the socket from client ::ffff:192.168.1.23
2021-03-21 01:12:10,975 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-21 01:12:11,007 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2021-03-21 01:12:11,008 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:12:11,011 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:12:11,077 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-03-21 01:12:11,099 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:13,106 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2021-03-21 01:12:13,108 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:15,112 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2021-03-21 01:12:15,116 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:17,121 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-03-21 01:12:17,146 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-03-21 01:12:17,160 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-03-21 01:12:25,512 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-03-21 01:12:25,545 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2021-03-21 01:12:25,546 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:12:25,547 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-03-21 01:12:25,594 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-03-21 01:12:25,611 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:26,531 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-03-21 01:12:26,557 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:28,696 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin Ver 1.70.2 BL (Creality3D)"
2021-03-21 01:12:28,702 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-03-21 01:12:35,590 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: temperature.gcode, owner: Greg, user: Greg
2021-03-21 01:12:35,609 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-03-21 01:12:35,615 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: temperature.gcode, owner: Greg, user: Greg
2021-03-21 01:12:35,625 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-03-21 01:12:37,654 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-03-21 01:13:02,322 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2021-03-21 01:13:02,339 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-03-21 01:15:39,476 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.23
OctoPrint 1.5.3
OctoPi is TH3D EZPi which uses a RPi-4B ver 1.2 preloaded with Octoprint
