So I am trying to control a non-TP-Link smart plug with the IFTTT plugin. The plugin works to turn the smart plug on when the print starts. But it doesn't work when the print finishes to turn the plug off.
In order to avoid melting my PTFE tube, I send and M81 command to the printer after the hotend has cooled to 48 degrees which should trigger the event "PowerOff". However, this doesn't happen.
I finally found the config.yaml file and it doesn't seem to contain any of the events that I found here https://docs.octoprint.org/en/master/events/
I don't understand everything that I need to add to the yaml file to be able to add an event. would I just type it like this:
events:
enabled: True
subscriptions:
-event: PowerOff
command:
M81
type: gcode
thanks
