Help, how connect Ender 7 ?
Ayuda, ¿cómo conectar Ender 7?
Warning: Firmware Broken
Yes, It does not work
octoprint-systeminfo-20211022040900.zip (93.3 KB)
OctoPrint Version 1.7.0
OctoPi Version 0.18.0, running on Raspberry Pi 3 Model B Plus Rev 1.3
Printer Ender 7
Firmware Ver 1.0.20T
Browser Firefox
operating system Windows 10
Have you tried pressing 'learn more' and installing the fix plugin?
Yes, on that page it says this for:
- Ender 3
- Ender 3 v2
- Ender 3 Pro
- Ender 5 Plus
- Ender 5 Pro
- Ender 6.
But not for Ender 7.
It says 'there might be more' - the list is not exhaustive.
Thank you very much really
I'll keep looking
When it solves I inform you
Muchas gracias de verdad
Seguiré buscando
Cuando lo resuelva les informo
Solo necesistas installar el plugin mencionando en el FAQ para solver la problema, estoy seguro. Puedo verlo en el log.
You only need to install the plugin mentioned in the FAQ to solve the problem, I'm sure. I can see it in the log.
edit
2021-10-22 04:02:06,700 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power. !!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
Ademas necesitas mejorar el power supply del Pi, no esta sufficiente.
Additionally you need to improve the Pi's power supply, it's insufficient.
