Help please 2nd webcam
cant add second webcam
pulling my hair out
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible<
i am running octoprint on a raspberry pi 4
i have 1 usb webcam working great but i cant add a second usb webcam,
ive read the [Setting up multiple webcams in OctoPi the right way]
but i dont have a octopi.txt file to copy so am lost.
any help would be much apreciated before im completely bald.
thanks
martin
If you are on a Raspberry Pi but you are not using OctoPi, then please share info about your setup and how you installed the webcam streaming in the first place.
hi i installed octoprint using the Setting up OctoPrint on a Raspberry Pi running Raspberry Pi OS
thanks
martin
hi here are the way the files are setup,
octopi.txt/webcam2.txt/webcamdaemon
any help would be great
thank you
martin
@Charlie_Powell
@foosel
Don't just ping me in order to get support! If everyone in need of help with OctoPrint did this, I could no longer work or even go online at all.
My apologies i didnt mean to be nuisance i do appreciate the hard work you do and octoprint is great and makes printing much simpler and better
Thank you martin
hi any help would be great anyone .
thanks
martin
Apologies, it seems I missed this post after I replied initially.
The guide you've used applies to OctoPi. Since you aren't using that but a manual install, the multi-camera setup won't work that way, instead I would imagine it requires more effort to duplicate the service files, you won't just be able to add a config.
thanks
martin
