Hi All, Just started using OctoPrint and I see an error message stating that my Firmware is broken.
Your printers firmware is known to have a broken implementation of the communication protocol. This may cause print failures or other annoyances, You'll need to take additional steps for OctoPrint to fully work with it.
I have searched here but I couldn't find anything. Any help would be greatly appreciated Thanks
Followed the learn more link. Takes me to the incorrect article.
N/A
Unless I'm missing something the article relates to a missing temperature graph. this is not my issue, the error I'm seeing is referencing a broken implementation of the communication protocol.
Issues with the temperature parsing are caused by broken implementation of communication. OctoPrint detected your printer sending a broken temperature report. So your firmware is broken in some way and that needs fixing. Best fix the firmware itself (creality stock firmware is notorious for all kinds of issues), otherwise install the suggested plugin.
So, I'm having the same problem, but I installed a BL Touch and flashed that firmware.
The main issue I see is when I print from Octo, the bed is about 30mm from the extruder. I installed the z Probe Offset plugin to no avail... But that's probably a topic for a different forum.
