I can't install plugins, I tried Spaghetti Dec. and Octolapse
I tried using the terminal to install, tried the github link, and obviously tried the repo on the OP UI
Yes
Not sure how to get systeminfo bundle.
I use OP on an HP Desktop running Ubuntu, as I can't find any RPis online for under $100, and I'm running OctoPrint 1.7.3, but my UI says 1.4.0, I ran a code to update.
Don't see anything about systeminfo bundle in my UI, which I assume is because it's not supported. I checked my version after my post, I'm still running 1.4.0, working on getting that fixed.
I really don't mean to be snarky, but what happened when you tried? Where did you get stuck? We really cannot help you unless you are more forthcoming with details.
Did you look at the plugin_pluginmanager_console.log ? Can you share it with us?
If the UI says you use OctoPrint version 1.4.0, what makes you say you are running version 1.7.3? What code did you use to update? What was the output of that code? Did it result in an error?
How did you install OctoPrint in the first place? Is it installed in a virtualenv, like recommended?
Your update to version 1.7.3 likely did not work, so you are likely still on version 1.4.0.
AFAIK, version 1.4.0 did not yet support Python 3.x, so you are likely still using Python 2.x. That may be part of the reason why installing plugins does not work. But all this is guesswork without logs.
I think it is going to be less work to start over, and install OctoPrint 1.7.3 instead of trying to figure out what is going wrong upgrading from OctoPrint 1.4.0.
I ran this code
~/OctoPrint/venv/bin/pip install -U octoprint
And I cant remember the output, something about uninstalling 1.4, and installing 1.7.3, when I try to enter it again, it gives a different output. No error, and I followed this guide to install OP in the firs place, no not recommended, this
