I have a leftover Retroflag NesPi+ case I was going to use for my Pi running Octoprint, however I would like to use the front buttons as intended (Safeshut Down)…
Has anyone had any luck adjusting the Retroflag provided script to work with Octoprint?
Its safe to say, I’m not very familiar with this process and only have a very high-level knowledge of python. Any help would be appreciated.
Installed the Retroflag script and removed any reference to emulation station. Pi just stuck in a reset loop?
I commented out the following lines in config.txt that the install ads
dtoverlay=RetroFlag_pw_io.dtbo
enable_uart=1
But it's now pretty unstable.
latest OctoPrint version, Pi 3b+, Ender 3 Pro
Hi @Ewald_Ikemann This is a good option, but unfortunately I don't know how the case is wired to the GPIO
Only info I can find is in the python script:
#initialize pins
powerPin = 3 #pin 5
ledPin = 14 #TXD
resetPin = 2 #pin 13
powerenPin = 4 #pin 5
#initialize GPIO settings
def init():
GPIO.setmode(GPIO.BCM)
GPIO.setup(powerPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(resetPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(ledPin, GPIO.OUT)
GPIO.output(ledPin, GPIO.HIGH)
GPIO.setup(powerenPin, GPIO.OUT)
GPIO.output(powerenPin, GPIO.HIGH)
GPIO.setwarnings(False)
you got the power button on gpio 3
and the reset button on gpio 2
Quick update... I never got the plugin working as intended. (likely my error) but I did find this script that seems to work.
RetroFlag:master ← TheExpertNoob:master
opened 06:09AM - 26 Dec 18 UTC
general support and some minor code changes for Raspbian users who may want supp… ort.
Its an old script, but no issues so far.
system
Closed
May 1, 2022, 6:52pm
6
