I used the Home icon on the control tab and it sounded like the on of the axes was trying to go further than what is allowed. I hit the arrow button once in the opposite direction and it stopped making noise. Is this a setting somewhere? Thanks
Looked around in the gui
no
no
Complete Logs
just updated 1.5.3 and 18
That's more of a printers firmware thing.
Octoprint just sends the home this axis command (G28 (Y X Z)) to the printer and the printer does the rest
The only other thing I can think of is that one or more axis was/were at the max coordinates when you started the homing.
If that's the case make sure that you pull those axis gently towards the center before homing next time.
I wish I could see the code it uses when it homes from the printer, it doesn't show it. I would expect the G28 codes to be it though. When I do it from the printer it goes there fine. I will just avoid using this from octoprint as I definitely don't want to crash it. Thanks for the help sir.
Hello
I know is a long time since your question but I've a MINI+ with octoprint and I have the same issue. Homing from the menu is ok but when I try from the octoprint interface it does the same as yours. Did you find a solution?
