Host action command
WRITE HERE i enabled host action command within marlin and no matter what i do it always shows HOST_ACTION_COMMANDS:0
WRITE HERE i have reuploaded different firmware from marlin after changing settings and i have tried adding new config to the marlin files and i cant figure out what the problem is
it didnt change anything
no
WRITE HERE just updated using this marlin file from sunlu https://3dsunlu.com/en/NewsDetail/3912708.html im on the latest octoprint version and im at a complete loss at this point.
Hello @Jewk_Me !
What have you activated/changed here?
//#define HOST_ACTION_COMMANDS
#if ENABLED(HOST_ACTION_COMMANDS)
  //#define HOST_PAUSE_M76                // Tell the host to pause in response to M76
  //#define HOST_STATUS_NOTIFICATIONS   // Send some status messages to the host as notifications
  //#define HOST_PROMPT_SUPPORT
  //#define HOST_START_MENU_ITEM  // Add a menu item that tells the host to start
  //#define HOST_SHUTDOWN_MENU_ITEM       // Add a menu item that tells the host to shut down
#endif
I removed all of the // that were before any lines with #define in that specific section. i also made sure that the advanced auto stop was enabled which it is by default on the s9+
I figured it out, the auto build marlin in vs code was producing a file that wasn't the same as the file I was editing, I found where vs code was putting the file when built. its working now!
