I just moved and left a lot of my tech stuff in another city. I need to set up my Pi to connect to a WiFi network, but I can't figure out how to access that file to conf it. None of the devices I have with me (except the Pi) have a µSD-slot. Can I edit it somehow via the OctoPrint web GUI? I don't think I enabled SSH, but I'm not sure. I got it hooked up via ethernet now, to my own network, so I can access it just fine and everything works.
Lots of fruitless research, mostly.
Not super relevant, no?
I'm using a D-link USB WiFi adapter and it should connect to a school network. Unfortunately, I don't know any specifics about the network, but it appears to be a perfectly regular WiFi.
