To the best of my knowledge, there are limited options for this.
Since you don't have a touch version of TFT, a mini keyboard would help, as described here.
Although you can install the TouchUI plugin plus the Raspbian Desktop and use a local browser on the Raspberry to visit OctoPrint on itself, since you don't have touch on your screen, it wouldn't really work that well and honestly, wouldn't give you what you're probably looking for.
If you're interested, you should read up on Conky and see if you'd be comfortable figuring out how it works.
Caveat: The scripts which periodically run on Conky to gather the information should be staggered so that they don't all run at once (which could labor down the four-core Raspberry Pi 3).
The original Robo 3D printer which I own came with the RoboLCD OctoPrint plugin which was created by a contractor and based on Kivy. It might be possible to use this code, refactor it greatly and just present a simple no-touch version to provide logistics.
