I was able to connect to my Raspberry Pi's OctoPrint URL and received the login challenge screen. For some reason, my "pi" user and password that I always use for such connections did not work on my Raspberry Pi/Octoprint instance.
I type in pi and the setup password I always use and got the error, "Incorrect username or password".
Since I would rather use a different user name to log in with full permissions what is the procedure to add such user so that I can log into the Octoprint and interact with my printer? .
I tried the command to allow for a user to set up once they access the URL but the new user dialog did not come up.
sed -i -e 's/firstRun: false/firstRun: true/g' ~/.octoprint/config.yaml
I read somewhere that a new user dialog screen would come up. But this did not happen.
Not sure how or if this would solve my problem if I did.
Complete Logs
I have the logs in a Zip file and are accessible from this link, https://www.dropbox.com/s/blvys03owxa450t/octoprint.zip?dl=0
OctoPrint Latest, OctoPi Latest, Crelity, firmware, FireFox, Raspberry Pi, ... as much data as possible
